Okay, I'm in kind of a bind and need some expert advice fast, hoping some of you [H]ard gurus can help. Let me tell you what happened.
I have a computer that I buit, e6400 @ 3.2ghz on Gigabyte's DS3 (p965) running Vista 32bit. Been running it for over 2 months with little issues, definitely nothing major... but then....
Today, I got a new monitor, dell 2407wfp, which has a card reader in it. I plugged the monitor up, and I was doing the things I do on the computer, nothing crazy, a little bit of gaming, a little bit of photo editing, a little bit of the internet, a little bit of dvd watching, whatever. In the mean time, Vista installed the drivers for the cardreader and asked me for a restart. It also installed an update, which I assumed was the animated cursor security patch that came out today. Anyway, after about an hour, I was done. I went and hit the 'pearl' (yeah...) to shut down, and away it went. Here's where the weirdness begins.
Before Vista shut down, it went through the 'Installing updates 1 of 1, do not turn off or reset' routine, which took MUCH longer than normal, but deciding to trust the disclaimer on the screen, I left the machine alone and went to get a drink and came back to find the machine had turned off. Finally, I thought to myself. I hit the power button to turn it back on, and windows won't boot. It went through the POST sequence fine, but after the 'scrolling startup bar' goes away, nothing... I hit reset, chose 'start windows from last known good configuration' from the boot error menu (the one that comes on if the machine shut off if windows doesn't boot all the way) and then... same thing. Okay, I thought to myself, then went into bios to switch the settings to 'load optimized' just to eliminate bios settings as a possibility, and tried again (so now I'm back to 2.13ghz) After a few more times of fiddling around, I got into windows, where explorer keeps crashing on me, I noticed that the updates were still being listed as available to install, I downloaded them and shutdown the machine again, WITHOUT installing the update this time... Ready for this? Now I can't get into windows at all! No Safe mode, no nothing! In fact, now the post sequence is ending with 'no operating system' like when you tried to boot from a blank harddrive! Worst yet, sometimes, the machine will get stuck at POST!!!
Here's what I've tried: Removing the pairs of memory (I have 4 sticks), switching the slots on the memory, didn't help. I tried removing any non necessary components, like dvd drives, then Hard drive to see if it would at least finish POSTing. Well, here's where I'm getting something. Without the hard drive, the machine would finish posting every time. Now, I can't go much further without a harddrive, so I had to plug it back in, but I put it in a different SATA port. Now the machine appears to be POSTing reliably. I booted from my Vista DVD (I think it's a dvd), to try to repair the install, but get this, Vista is saying that there is no Vista currently installed! Okay, so repair is out of the question, then I tried reinstalling, now it's saying that 'the volume does not meet the criterias required by windows' GAAH!! I don't want to have to reformat, there are valueble data in there that, although won't ruin my life it it goes away, will make it much more difficult in the coming months, so i'd like to keep that as an absolutely last resort.
I know I practically wrote a book telling you guys about my problem, so if you read this far down, thanks. I just wanted to be thorough. Anyway. if anyone has any idea what I can do to fix this, I would really, really, really, appreciate it!
Thanks!
Art
Thanks!
Art
