I know that there are certain 'Analog only' LCDs that only have one Dsub15 input. It takes the analog siganal that has been converted by the PC DAC and converts it back to a digital signal for the pixel array, usually resulting in a lower quality image.
Then I come across a panel like this, that has both a DVI and Dsub input. On newegg the specs claim that the monitor is 'Analog RBG', yet on the company website it states that the input is "24-Pin DVI-D".
If the monitor was analog, wouldn't it be using DVI-I?
I'm just wondering if this monitor actually picks up an analog signal through the DVI cable even though it has all 24 pins to work with, and then still runs this through its 'ADC'? Or, I'm hoping, that it just takes a complete digital signal and displays a raw image from your card. So basically I want to know if I'm actually going to see a higher-quality digital image when using the DVI input on this monitor, or is it doing some stupid analog trick with the DVI.
I know all of you are twitching at the thought of owning such a monitor, but when it comes down to the specs they're all being made in the same factory, and I'm freaking 14 years old and on a budget.
Thanks for the help!
