I'm starting to get together components for a water-cooled system, and for the time being, I'm just going to be doing simple straightforward watercooling...however, I'm considering that at some later point I may want to try using some peltiers and such.
What considerations should I make in buying my components *now* for possibly adding peltiers later?...
From what I can think of:
- try to get bigger/better radiator?
- try to get higher flow/head pump?
- PSU = no change, as I'll basically need a 2nd power source anyway
What about:
- water-blocks?? Are there certain waterblocks that are particularly easy to later add peltiers (but are still good without them)? Are there any waterblocks that should be avoided (perhaps due to shape?)??
Or anything else that is important?
Thanks!
Xylo
What about:
Thanks!
Xylo
