Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
Ok after I get said water cooling set up, what would be involved in maintaning it from time to time. Given Im not aways getting new blocks or pumps w/e.?
Yep, top off every couple of months if your fluid level is dropping, add more antialgae if what you're using tells you to, and otherwise it's generally good to flush and clean your loop every year or so, but generally, if your loop is running smoothly, your temperatures aren't getting worse, and your loop hasn't lost any water, it's better not to mess with something working fine.
