Mar 27, 2006 #1 G geckoman Limp Gawd Joined Feb 9, 2003 Messages 325 My nvidia 6800 gpu is currently at 67 C, with an ambient case temp of 38C while surfing the net and such.. what is "acceptable"?
Mar 27, 2006 #2 R rox1co [H]ard|Gawd Joined Feb 1, 2006 Messages 1,104 that's acceptable my idle is around the 40s so ur doing real good and i've never gone above 70C on full load
Mar 27, 2006 #3 2 2gigs [H]ard|Gawd Joined Dec 4, 2005 Messages 1,200 that is fine,. 75 and higher, i get a little weary, if that bothers you, get a new cooler though
Mar 27, 2006 #4 J James24 Gawd Joined Dec 14, 2005 Messages 531 How old is the card? Could be a little dust build up inside the unit. While it's acceptable it is a little high. Should be in the high 50's. How is your case cerculation? Do you have good airflow?
