What Cooling Should I Use?
JMack986
here are a few of the specs i am building on to my pc i just though this is going to poduce alot of heat what would you say the best option for trying to keep this system cool?
SPECS
Case
XG Dragon Aluminum Gaming Case Black * No Psu*
Power fan:
650Watt Modular Power Supply Microsoft
Motherboard:
Asus A8N32-SLI deluxe Motherboard
CPU processor:
AMD Athlon64 X2 FX-60 Socket 939
Cooling:
Icon Water-cooling Kit (AMD)
Memory:
2048 MB Corsair 3200XL PT 400MHz 4x512mb
Graphics cards:
2x nVidia GeForce 7800 GTX 512MB (BFG
Hardrives:
WD740GD Raptor 74GB 10000RPM 8MB SATA
Seagate ST3400832AS 400GB 7200 RPM SATA
CD-DVD burners
Lite-On 16X Dual Layer DVD+-/RW
Lite-On 52x CDRW
Sound card
Creative Labs X-Fi Fatal1ity
Silencers
Silencer 80MM Case fans
thx for reading
JMack986
Custom watercooling. Either 120.2 heatercore or 120.3 BIX, pump like the D5, TDX or Storm G4 CPU block, throw in a GPU block if you want, use the thick tubing.
