Can't get my Opty 165 past 225 and have a few other issues.....possibly.
I am a newb when it comes to OC'ing...only overclocked 4 procs before and they were all Intel Chips. The last thing I overclocked was a P4 478. So if I am asking a dumb question be gentle I am still a newb...
System specs.
ASUS A8r32-MVP Deluxe
Opteron 165
G.Skill 2gb PC4000 DDR 500 3,4,4,8
Sappire X1800XT
WD 250g SATA2
Anyhow Here are my questions.
1.How do I change the freaking CPU voltage? The max allowable for me is 1.4v.
2. When I originaly boot up after a BIOS error and default settings reload I have to go to the BIOS and change the following or it will not boot at all and just hangs up during initialization.....
boot settings config> Wait for "F1" if error:-----------disable
Full screen logo:------------------------------------------------disable
3. My system hangs up during initialization at the USB bus initialization for about 20seconds and then finishes no problems after that. Is this a problem? If not is there a way to stop this slowdown on bootup?
4. There is no workaround to get a USB keyboard to work in the BIOS? I have to use a very old PS2. Talked with ASUS they said no... thought I would ask people that actually used the product though.
5. In CPU-Z (v1.33) on the SPD tab it shows my memory as being 3, 5, 5, 10.....now the memory is supposed to run at 3, 4, 4, 8 . Is the SPD screen what the memory is supposed to be running?
Here are the BIOS settings I had to use to get thus far. (BTW thanks Psychlone for the Format...I blatently stole it)
ADVANCED
_Jumper Free Configuration
_AI Overclocking__________________ Manual
_CPU Frequency__________________225
_PCIE Frequency_________________100
_FID/VID Change__________________Manual
_Processor Frequency Multiple______X9
_Processor Voltage_______________1.40V
_DDR Voltage____________________2.80V
_VCORE Voltage_________________+100mV
_Northbridge Overvolt______________Enabled
___Core Voltage__________________1.2V
___HT Bus Voltage________________1.2V
___PCIE Voltage__________________1.2V
_PEG Link Mode__________________Auto
_PEG Buffer Length________________Auto
_AI Clock SkewA__________________Auto
_AI Clock SkewB__________________Auto
_CPU Configuration
_GART Error Reporting_____________Disabled
_MTR Mapping____________________Con tinuous
_Cool N Quiet_____________________Disa bled
_HT Link Speed___________________1 GHz
_Memory Configuration
_Memory Timing Mode_____________Limit
___Memclock Value_______________200
_MCT Timing Mode________________Manual
___CAS (CL)_____________________3
___TRAS_______________________ _8
___TRP________________________ _4
___TRCD_______________________ _4
___TRRD_______________________ _2T
___TRC________________________ _7T
___TRFC_______________________ _16T
___TRWT_______________________ _2
_MCT Extra Timing Mode___________Manual
___TREF_______________________ _7.8us
___DDR Input Strobe Skew_________Disabled
___Burst2Opt__________________ __Disabled
_User Configuration Mode__________Manual
___Read Preamble________________5.0ns
___Asyc Latency_________________7.0ns
___CMD-ADDR Timing_____________1T
_Bank Interleaving_________________A uto
_Burst Length____________________4Bea ts
_Software Memory Hole____________Disabled
_ECC Configuration
___DRAM ECC Enable_____________Disabled
___L2 Cache BG Scrub_____________Disabled
___Data Cache BG Scrub___________Disabled
_Chipset
___VGA Priority___________________1st PCIE ->2nd PCIE
_HT Config
___HT Link Speed_________________1 GHz
___CPU:RD580-NB HT Link Width____16 Bit
___RD580 HT Link Three State_______Disabled
___RD580 HT Drive Strength_________Optimal
___HT Receiver Comp. Ctrl__________Optimal
___RD580 HT PLL Control___________High Speed
_PCI-E Configuration
___PCIE GFX1 Link Width___________X16
___PCIE GFX2 Link Width___________X16
___P2P Writes Between GFX Ports___Disabled
___10% Extra Current Between GFX__Enabled
___10% Extra Current Between GPP__Enabled
___10% Extra Current Between SB___Enabled
___10% Extra Current Between GFX1_Enabled
___10% Extra Current Between GFX2_Disabled
System specs.
Opteron 165
Sappire X1800XT
WD 250g SATA2
ADVANCED
_CPU Configuration
_ECC Configuration
_Chipset
_HT Config
