What am I doing wrong?
BigFNDeal
Specs in sig.
I can't this setup to goto even 2.95 on air. My temps are fine, as I barely get over 40degC running P95. But at 2.95 P95 crashes immediately. I believe my CPU is locked at 14, so any changes to multi are out. I am able to get P95 to run for at least 8 hours at FSB = 829 and Memory = 690. I upped my cpu voltage to 1.265 and my memory voltage to 2.1, but still nada at 2.95.
Is there any way to access multiplier on this chip?
I believe only EE versions allow you to access multiplier.
I'm throwing in the towel for now. I don't really want to loosen my timings at all and it doesn't appear that I can alter the multiplier, so I guess I'm stuck. I got it to 2.9GHz (FSB = 829) while running memory at 675. Anything higher and even though I can run P95 for hours, I seem to have acquired BSODs every now and then which I was never getting before. So I'm stopping for now. I guess this is the best I can do stable until I move to Conroe.
