D
Deleted member 12106
Guest
I bought this board 7-11-2013 as an open box from NewEgg, and just opened it today to setup for anticipated CPU delivery.
On Newegg Chat...
sc0tty8: Order #182461203 is the order for this board.
Elena: Thank you for holding. As of this moment, we can issue an RMA for refund for you. You can reorder then. Could you please give me a brief description of the issues you’ve experienced with this item?
Elena: Do you have the retail box and all the accessories?
Elena: Please kindly note that if the item was returned and tested as physical damage, your RMA will be denied.
sc0tty8: first, yes I have the box. second, the board arrived damaged
Elena: Thank you. I have issued you RMA for a refund. You will receive a confirmation email within 5-10 minutes containing the address and instructions for your return. Once received, we will process your RMA within 2-5 business. After the RMA is processed, a refund will be issued to your original payment method within 3-5 business days.
Elena: Also, a second email will be sent to you within the next 24 hours with a prepaid UPS shipping label. Please print the label and tape it onto the outside of your returning package. This label does expire in 7 days, so please make sure you send this package as soon as possible or you may have to incur the return shipping cost.
sc0tty8: right, however above you made mention of damage, I would be denied if the board is damaged?
Elena: If the motherboard is physical damaged the RMA will be denied.
sc0tty8: thank you i got that but are you listening? the board arrived damaged please look at the photo above...
