Hello, was wondering if anyone had any suggestions for me as I'm not super savvy with electrical stuff.
I'm having an issue with my USB ports where, each time I get up from my computer, some of my USB devices will stop working. The noise indicating I've unplugged them will sound, and it will do so again when I return. It doesn't happen at all while I'm actually there. No amount of vibration on my part or anything else seems to affect it. It literally only happens when I get up and sit back down. This recently started happening after I moved into a new apartment, I suspect something is broken but this problem just seems really weird...
I had a separate issue a while back where the USB ports sometimes wouldn't work when I restarted my computer and that turned out to be a a faulty ram issue, however the symptoms I'm having now were not present then. Does anyone have any ideas what could be causing this?
