weird question
X85A
this might be a weird question but i need your help in getting a "stand" for my display.
im upgrading from my old powerbook g4 and getting a 15" macbook pro C2D. i have an external monitor (dell 2005wfp) and usually run my laptop in close-lid mode.
with the powerbook, it was not a problem. all the ports were on one side and the cd drive was on the other so i just put away on a small stand next to my desk with the cd rom facing me so i can "hide" all the cables"
however with the mbp, there are ports on both side (ie. power is on the left, dvi output is on the right) and the superdrive is on the front of the mbp. so this is where i decided to look for some sort of.. stand/shelf/whatever where i could place my laptop under and my monitor on top. it has to be roomy enough to allow the cables to plug in.
any suggestions would be helpful! :)
