weird hardware peripheral issue
pppbigppp
Hi,
I had been using this computer for 5 years (XP2) and it work fine up to now. Recently, I start to notice a large amount of hissing/static white noise coming out of from the speaker, even when no sound is being played. I can control the noise level using the volume control, but I couldn't find anyway to completely shut it off.
So I start to isolate the problem and see what causes it. I ran different OS and the problem persists. The speaker system also work just fine on another computer. So I took apart the computer and took out the sound card and plug it into a different computer. Surprisingly, it also works just fine. Then I put everything back together and everything magically work together
Of course it ain't going to be so easy. I played an audio clip for testing purpose and within 3 min, the hissing noise slowly and surely creeps back. So I took apart the computer again and that's when I notice the sound card is right next to the video card, which is very hot. I notice that the little fan on the video card does not spin when I think it should. So is it possible that thermal heat is the root of the issue?
Of course, the immediately solution is to relocate the PCI sound card. But when I do that, my OS couldn't detect the sound card at all. What happened to plug and play?
All right, any suggestion what my next move should be?
Could be heat. Although it is typically recommended to place the sound card as far from other cards as possible to reduce the affect of interference.
