I just put together a build and I seem to get a weird freezing problem after about an hour of Orthos or sometimes while watching a movie or something.
According to Speedfan, the processor idles at around 40 and gets to upwards of 58 after ten or so minutes running Orthos. This is with the side panel off...CPU temps are a bit high but this shouldn't be the reason for crashing right?
This is what the screen looks like when it crashes:
Basically, it's a whole bunch of my desktops resized it seems. If I have music or a movie playing, the speakers will play a really annoying screeching/static noise. I've ripped out the sound card and am running the test again, but I honestly think it might be the northbridge overheating/malfunctioning since I'm using onboard temporarily.
What do you guys think? Would a discrete video card reduce the load on the northbridge enough to reduce temps?
Specs:
Athlon x2 6000+ w/ stock cooler
Gigabyte M61P
4x1gb Micron PC5300
X-fi Xtreme Music
Antec Trio 550w
EDIT: I'm running MemTest86+ at the moment and it just passed Test 5 fine. Will let it keep going...
Specs:
Gigabyte M61P
4x1gb Micron PC5300
X-fi Xtreme Music
Antec Trio 550w
