WC Questions
iownyou14
Got a few q's
1. Im thinking of getting a Bay Reservoir and i see that it has a 3/8" ID fill hole. Can I connect a fillport at the top of the case to the fill hole on the reservoir via 3/8" ID Tubing??? So i can fill it using the fillport and it goes through the tubing into the reservoir.
2. Im also thinking of getting a DangerDen Black Ice Xtreme II Black Radiator and installing it on the top of the case with the fans on top of the radiator. I want to add a grill @ the top (kids in house and fingers going everywhere). Which grill would perform better and let more air out/in: normal 2x 120 grill or the Aqua Computer Airplex Evo 240 Grill?
3. What fluid do you add in your system. Im thinking Distilled Water, Innovatek innovaProtect Fluid, and some WaterChill Anti Algae Fluid. Are there any other combinations of fluids that will protect and prolong the life of my system (i.e improve flow, stop organisms, stop corrosion, etc)??
Thanks for all your help!
