Kninetik said:You got the heatsink holes mixed up. Water goes through the accelerator into the center then pops out on the outside
gniticxe said:You might get a very small performance increase if you put the heat exchanger right after the pump. The pump heats the fluid ever so slightly, so with the radiator placed after it, you'll get a slightly cooler liquid to the CPU.
While the benefit may be small, it couldn't hurt - especially because you're putting it together.
Thanx.lanolar said:Correct
