videogamer323
- Jan 31, 2003
Ok i have the Lian Li PC-75 with
6 enermax adjustable fans installed, 2 intake front, 2 intake rear (at proc), 2 exaust top (above PSU)
92mm tornado on Heatsink
My ambient temps are about 5 degress F over room temp at the top of the case
CPU runs at around 49C (120F) at max load at around 30C (85F) room temp
To me that seems quite good
So would water cooling be worth the money (if i go im going ALL OUT)
Noise isnt a real issue to me, but thats seems like the only reason for me to switch at this point cause none of my components are limited by heat...
Probably would spend around $300 on a custom setup
