I recently bought water cooling (storm (cpu block), MCR-220 (rad), MCW-55 (gpu block), MCRES-525 (res), MCP-655 (pump), and 7/16" masterkleer tubing).
It's all installed and stuff, and I'm leak testing. I did the paper clip trick to start just the pump and it kind of sputtered, pumped a bit of fluid out of somewhere, and I stopeed it. I cleaned up a bit and moved the only two clips I have to the outlet on the pump (where I think it came from) and tried it again. Now whenever I start it the pump makes noise but doesn't pump anything. Could it be a block in the tubes somewhere?
I have the pump up on the side of my case right below the psu with the inlet barb pointing straight down and the outlet pointing outward (away from the mobo). This is because my GTX doesn't leave any space open on the floor of my case except where teh HDD case is and I can't remove that (or I don't want to) because I only have 2 3 1/2" drives and one of them has a floppy in it but I have 2 hard drives.
My case is the Gigabyte 3d Aurora.
Anyone have any ideas?
