nytrackstar
- Aug 3, 2004
aright so i installed my swiftech h2o ultra kit with the apogee waterblock. I added 2 mcw55's to cool 2 256mb gtx's in sli. I also replaced the stock res with a much larger res that takes up two 5.25 bays.
i have the radiator in the back of the case like in the swiftech diagram and the fans are not as quiet as i expected them to be. the pump at full speed is nearly silent but the fans in the back are pretty loud. can i connect them to some kind of fan controller? maybe slow them down a bit?
due to a lack of right angles for the tubing and tight spaces i had to run the loop like so:
Res -> pump -> GPU1 -> Proc -> GPU2 -> Rad -> Res
At stock speed and stock volts my x2 4400+ idles at aound 35-36 and at full load(dual prime95 for a few hours stays at 39. Im using SpeedFan for the temps.
both Graphics card idle at 33-34 and underload hover around 38-39
i removed the heatpipe from my a8n32-sli and placed 2 zalman northbridge heatsinks on north and south brigde, the temp i get from the nb reads 68c...this is rediculously high..
opinions on the temps other than nb?
my plan for when i get home in 2 weeks is the following...
buy some right angle connectors, extra tubing, and nb block.
will reroute the loop like this:
Res -> pump -> Rad -> Proc -> GPU1 -> GPU2 -> NB -> Res
I figured ied get the best temps if the water came fresh out of the rad...
opinions? advice? tips? will this load be too much for the loop? i'm still hoping to get a decent oc and somewhat quiet operation. This too much to ask?
