Water Rig on Deck
Metrocall
Alright well I figured I would share this as it seems(to me) very interesting and something I have wanted to try for a while. Also the chip is the same as in this last thread I did:
http://www.hardforum.com/showthread.php?t=1419703
Basically I have done as the title suggests, put my rig(in sig but a 4850 instead) outside. The temperature is roughly 55F(12.6C on temp probe) and the water temperature is reading at about 15C.
I can not tell what my temperature it idles at as the readings stop at 37/24. On prime95 and IBT however I end up with this at stock:
After a bit of raising he FSB 5mhz, than setting new clocks in BIOS every 100mhz, than getting to 4ghz I end up with this. Those max temps stayed there even after 2 more sets of 2 passes.
I am still following that process and have so far gotten to 4.2 with no issues. I am going to continue this process and hopefully pass my own personal record(in thread listed above). I'll keep updating as I hit milestones.
Here are some pics of interest as well.
Southern VA but in the mountains. Although I plan to stop sorta soon the temp is supposed to go to about 38F tonight. And also the water temp has gone down to 14.6C and the air is 11.4C.
Alright I was able to boot 5.1 with 1.6v... I'll be trying for 5.2+ probably tomorrow but for now I'm off to bed.
That's awesome. I would try that, but I think rain would get to mine. 5.1GHz is amazing btw.
