Network_sheikh
- Mar 13, 2005
what do u mean by water cooling???!!!!!
WTF guy. read pretty much any thread in here and you should get some idea of what it "means" yourself.Network_sheikh said:what do u mean by water cooling???!!!!!
lol pwndDFI Daishi said:WTF guy. read pretty much any thread in here and you should get some idea of what it "means" yourself.
bad question, very bad questionNetwork_sheikh said:My question was :is water cooling very important for us?
lt.murda said:If you dont know what water cooling is..You don't need it.
Russ said:Yes, water cooling is very important to "us."
You see, water cooling cools the water in the world. Without it the heat from the sun would eventually boil all the water and Earth would look like Mars (they didn't cool their water).
So you see, computer geeks water cool to save the planet, not to play video games. Water Cooling is a very important part of the Earth's ecosystem, and it lets us blow up cooler looking Doom 3 aliens.
[/sarcasm]
Actually, water cooling is a method of replacing the fans in your computer with a system of tubing and metal blocks to reduce heat. The metal blocks mount on your processor and sometimes video card/northbridge/hard drives. They absorb the extreme heat these parts produce and the water running through them absorbs this heat and brings it to a radiator, which is a device for dissapating the heat in to the air. Running all this is a pump, which moves the water through the tubes to these different parts of the apparatus so that it is continuosly cooling your computer. Those are basically the main parts of a water cooling system.
Nikola said:Actually, supposedly according to National Geographic, there are large parts of Mars that are frozen ice.
Top Nurse said:That was the part of the planet where they played too much Doom and the phase change and TEC's got out of hand.![]()
it got really gory at the end. the nationalists insisted that the red dominator pro that was sent out tor the reviewers was the only way to cool, while the younger generation liked the sexy blue arctic web.Top Nurse said:That was the part of the planet where they played too much Doom and the phase change and TEC's got out of hand.![]()
