water cooling
ne0-reloaded
thinking bout going the watercooling route bout dont know where to start. it's hot as hell in my room and even with 6 fans, not including the hsf, i still get temps of almost 50c. i used to only be at 37c under load, but i guess i have to reapply some more as3 or something. anyways, its 2 damn loud and not cooling enough. any links with any info about it from places to buy from to buying the right parts would be appreciated
thanks
I just got a water cooling setup...currently in the leak testing phase before i put my PC into the case...
i got the following items:
DTek LRWW with ally top
Eheim 1250 pump
Thermochill 120.2 Rad
Dual 3.5" Res
all with 1/2" fittings and tubing.
Not sure where you would buy in the US, i think DTek have a website u can buy direct from...as for the pump and tubing, i ordered that from an aquatics store. Fans i guess you can get from ur regular PC parts store....
hope this helps. I am sure some of the guys from the US on the boards will be able to sort you out with links to shops.
I tell you one thing tho...i had no concept of how quiet a water pump would be...it plugged the thing in last night and had to make sure it was on by checking the flow and feeling the pump for vibrations....all i can say is water cooling is damn quiet...
Originally posted by kronchev
you dont save much from those places...
www.dtekcustoms.com
You have any proof to back up that statement? Do you even know what parts you can get from each vendor I linked to? Dtek has some pretty high prices for a lot of their parts.
i only pointed to dtek for blocks. pumps are pretty much the same all places, where you linked has other brands like danner mags
Nice ninja edit pal.
Nice ninja edit pal. Ugh, get a life.
wow I added a link that didnt change anything and its a ninja edit? calm down. you dont seem to realize that im usually on your side in watercooling matters...
Chem quizzes and all nighters make giblet cranky, sorry. :eek:
Eheim 1250 pump
Dual 3.5" Res
how much did all that cost u syphon?
