Mithosphere
- Apr 19, 2014
While not technically for a computer rig, what would be a good water cooling setup for a backpack system?
I've looked at a dozen different cooling parts, but need some better recommendations as to the actual cooling performance of individual parts and the rigidity/long-term wear-and-tear. The water cooling setup will need to include a radiator or two and a pump, with or without a reservoir.
Why do I want such a system?
I'm currently in the design stage of an elaborate costume and need to adequately cool my upper body. In conjunction with an active cooling vest (tubing stitched into fabric), the water cooling system should perform better than a cooler filled with ice water... not to mention the possibility of better ergonomics and weight distribution.
I've posed this question to my brother-in-law (he has made a few custom computer rigs and other bits made from acrylic) and we've yet to come up with specific parts for the system.
The cooling system will be housed inside of a custom-made backpack, but the radiator(s) can only be placed in certain areas (due to the design).
Here's what I'd like some information on:
120mm-240mm radiator size efficiency
Pump power consumption
The necessity of a reservoir
