thyshallsmite
- Aug 17, 2005
http://www.newegg.com/Product/Product.asp?Item=N82E16811144162
I'm going to use this case, and i want to put a nice water cooling in this system so i can overclock a Pentium D 805 to 4.0ghz or higher. I've been looking around and haven't found a nice system that i could put in that small of case. I'm considering http://www.xoxide.com/koolance-rp-1000bk.html , but not seeing any reviews on it so not sure. Was also considering an external system and screwing it onto the case itself.
Sooo my questions are:
Which external water cooling units would you recommend the same or near same size as this case?
Which internal water units would you recommend that would fit in that case?
Would you recommend the RP-1000?
