robble
- Jun 6, 2004
I was thinking of getting this:
http://www.dangerdenstore.com/product.php?productid=189&cat=48&page=1
For cooling the 7900gt I plan on getting. I read a review though where it said it didn't cool the ram chips on the back of the card. I don't even know if the 7900gt HAS ram on the back. If it does, I may want to go with the mcw-60 and get the ram sinks.
I'd like great overclocks but watercooling the vid card is mostly for noise.
What do y'all suggest?
I've also ordered the following and just waiting for it and the rest of my opty stuff to arrive.
I didn't order the full kit because I had already ordered an apogee cpu block that I'm still waiting for.
Qty Product Unit Price Total
2 Fitting: 1/2in. barb to 3/8in. NPT - Part # A6-8 (set of 2) $1.00 $2.00
1 MCW30 Chipset Cooler $29.95 $29.95
2 MCB-120 "Radbox" Revision 2 kit - Black $19.95 $39.90
1 Radiator - MCR220 Quiet Power Series DUAL120mm - Gloss Black $42.95 $42.95
1 MCP655 12 Volts Industrial Pump $84.95 $84.95
1 MCRES-Micro Hi-Flo Reservoir $14.95 $14.95
1 Tubing: 7/16 in. (ID) x 5/8 in. (OD) Vinyl Tubing x 10 ft. $8.00 $8.00
1 HydrX Coolant $1.85 $1.85
1 SmartCoils 625 Blue $3.10 $3.10
Sub Total: $227.65
UPS Ground: 18.36
HonoluluTax: $0.00
Grand Total: $246.01
Sub Total: $227.65
UPS Ground: 18.36
HonoluluTax: $0.00
