I'm in the process of building a water cooling setup. I have already purchased the following:
Laing DDC-2 (18W) + Alphacool top + Alphacool res
Black Ice Micro II (This is going in a HTPC case with limited room)
I have decided to stick with my current hardware and need to pick out water blocks for my CPU and GPU.
CPU: Opteron 165
GPU: Radeon X1900XT
For the CPU block, I'm thinking the Swiftech Apogee. I'm also wondering why their website shows the Apogee outperforming the Storm, but the Storm is more expensive? Is the Storm better for this pump? (I've found conflicting opinions on this and am looking for some proof one way or the other) I'd like a universal solution so that if I do upgrade to a Core 2 Duo in the future, I am still able to use the same CPU block.
I'm not really sure on the GPU block. I'd like to keep it cheap in case I upgrade my video card next year and the block isn't compatible (which it likely won't be). Maybe a Maze 5?
Currently I'm thinking Apogee + Maze5. My budget is about $100, but I could go up a bit on this.
Edit: Also, what are those fittings I see people using that have the tubes on the inside of the fitting instead of the outside?
CPU: Opteron 165
GPU: Radeon X1900XT
