Ok, so I noticed that my temps were getting a little higher than usual, so i went ahead and took off the block to make sure i was getting good contact and nothing was lose, and i noticed something was lose. so to tighten it i have to remove one of the tubes, so i drain all the water out and get started. i get the mainboard out, everything pluged in, i tilt my case back up, and NOOOOOO water from the radiator i have mounted on the top of my case, spills out and drips down through the mainboard. Nothing was on though.
I pulled out a duster and emptied the entire can on the board, doesnt seem to be any wayter anywhere.
If i let it totally dry will it be ok?
if i can let it dry then power up, how long till it dries?
