Watcha think?
IceCuban88
Hey peoples, wat do u guys think about my WC job. It's my first time with water cooling. Its a very tight fit in my Superlanboy. I get around 36°C idle now, i used to have 45°C with my old zalman HS. Its max is around 52°C now, but if i speed up the fan its like 48°C max. look in sig for details. There are no lights inside the case only a UV light, I like darkness... helps me sleep.
I really like "Napoleon Dynamite" as you can tell.
LIKE A TIGHT FIT!!
YESS DARKNESS
I OC this sucker to 4.046 Ghz but with 1.6V (deng D0 stepping), is that too much voltage or wat?
eeeeewww, get rid of those 90 degree elbows, will greatly improve performance, and if you absolutely cant get rid of them go to home depot and look around for some copper bends, they are much smoother than 90 degree bends and dont have the pressure drop of those acrylic 90 degree bends.
Nice setup.. :)
Looks like you'll be leaping lightly into lanning with with your lusterous, luminous, liquid Lanboy.... :D
i agree entirely, and from those pics you have, it looks like almost any tubing could make those beds without kinking man
Ummm... NO. I used to have it without the 90 degree bends, did not work, it was kinked like a mofo. I had to put those clamps on the tubes just to keep it from kinking. Its tygon anti-kink too, i get better flow this time with the 90 degree bends. If i had a bigger case it wouldnt be a problem. But i got this itty bitty case, and i am not going to a new case.
if you cant get rid of the bends, pick up some copper bends at home depot, they have a much softer turn than acrylic 90 degree bends, and like 1/2 or 1/4 the pressure drop.
What block do you have?
Guess that is alot like what my 3700BQE will look like (minus the bends :eek: )
Probably not since the SLK3700BQE is MUCH bigger!
