Has anyone come across this? I have a Linksys switch setup using VLANS for pfSense, wireless AP, etc. I create a new VLAN on the switch and configure the ports as well as configure the new VLAN on pfSense and re-assign the interfaces. I then move the cable modem from the WAN port of the pfSense to the correct port on the switch and the WAN connection works for a few seconds and then completely stops working.
A few years ago I tried a similar setup with the same or similar switch and had the same results. The only difference was that I was not using VLAN tagging
