tiebird321
- Jun 6, 2004
so because of the recent huricanes droping telephone lines left and right
the telephone company redid the lines....
cept they did a craptacualr job doing it
so my very happy line that was syncing at 6.0/1.5
will only work reliably now at 1.5/768....
so because of the SLA i have with my ISP
the ISP has offered to install a second line
to get me back up to 3.0/1.5 at a base minimum
the problem i have is how to load balance the 2 lines
what i figured i might be able to use would be an old base 10 core router that has multiple WAN ports...
but i'm not to sure about it
the thing does not need to do DCHP or firewall
the way i have things set up is as follows
i have a house/small buisness network running dhcp behind a nat firewall/router
there is a freebsd server for the buisness
and then there is the singular adsl modem
the router and the server each use a static IP addr
and the router server and adsl modem are connected together via a base 100 hub
i want to keep it the way it is and just add a device between the hub and the now 2 adsl modems
is there any way to do this using hardware
or using a p3 500 box runing debian and software with like 3 lan cards
thanx for any help at all
