First off, many thanks to seven9st surfer over at OCN I saw his wallmounts and wanted the same! and used a similiar system
So I jumped to eyefinity a few months ago and have been pretty stoked.
As you can see no deskspace, looks like poo, etc, so I decided to wall mount them up. but I wanted something cheap and easy...
1/2" poplar. this will be the part attaching to monitor, and then go in a track that is mounted to the wall
and attached to the back
the track
countersunk all the screws so they wouldnt obstruct the channel
attached fabric to the back of the track, so it wouldnt take all the paint off the walls
track up, and looking pretty hagard
little test, and it works!
got all three of them up there, you can see the remnants of my top shelf I took down
mounts
sad monitor stands
The disgusting piece of machinery powering all this
windows up, the (current) finished project
Could have gone better but overall im pretty pleased
Im going to be putting a small shelf back up to put my pc back up above the monitors, instead of under my desk
Because of the size of the monitors and their distance away this flat panel actually feels convex, not the concave desired by eyefinity. So Im planning on angling the out displays in a bit. and I would also like to remove the bezels, anyone got any helpful info on that?
and of course when im done ill hide the wires completely
and its super nice having (6) usb ports right on my desk!
the track
mounts
sad monitor stands
