- Feb 10, 2001
I'm trying to use vmware converter and convert a running machine to a VM.
Problem:
I have ran chkdsk /r c: many times, here is the last output:
Anyone have any ideas on getting around this problem so I can make a VM of the system? System is a windows 2003 server that I'm remotely administering. The C drive is all of 12gigabytes, and I really don't want to create a new install of windows to replace this server at this point in time as there are many mapped drive and printers that people rely on this server for. Microsoft backup software is failing with the same volume shadow copy issue.
Problem:
Code:
The shadow copies of volume C: were aborted because of an IO failure on volume C:.
For more information, see Help and Support Center at http://go.microsoft.com/fwlink/events.asp.
Code:
The device, \Device\Harddisk0, has a bad block.
Code:
Checking file system on C:
The type of the file system is NTFS.
A disk check has been scheduled.
Windows will now check the disk.
Cleaning up minor inconsistencies on the drive.
Cleaning up 48 unused index entries from index $SII of file 0x9.
Cleaning up 48 unused index entries from index $SDH of file 0x9.
Cleaning up 48 unused security descriptors.
CHKDSK is verifying Usn Journal...
Usn Journal verification completed.
CHKDSK is verifying file data (stage 4 of 5)...
File data verification completed.
CHKDSK is verifying free space (stage 5 of 5)...
Free space verification is complete.
12586927 KB total disk space.
8121852 KB in 25922 files.
9512 KB in 5142 indexes.
8 KB in bad sectors.
644403 KB in use by the system.
64992 KB occupied by the log file.
3811152 KB available on disk.
4096 bytes in each allocation unit.
3146731 total allocation units on disk.
952788 allocation units available on disk.
Internal Info:
70 c7 00 00 64 79 00 00 a0 a0 00 00 00 00 00 00 p...dy..........
47 05 00 00 06 00 00 00 32 02 00 00 00 00 00 00 G.......2.......
f6 a0 0b 03 00 00 00 00 00 49 7f 0f 00 00 00 00 .........I......
0e 8f 90 09 00 00 00 00 de c7 d7 9f 00 00 00 00 ................
f0 b1 fe 5e 00 00 00 00 ba f0 cd 35 01 00 00 00 ...^.......5....
90 2b f3 e1 00 00 00 00 cd 9d 82 7c 03 00 00 00 .+.........|....
42 65 00 00 00 00 00 00 00 f0 b7 ef 01 00 00 00 Be..............
Windows has finished checking your disk.
Please wait while your computer restarts.
