Ok, I bought this pump Danger Den DDC-12V from you a few months ago and just installed it a few days ago. My question is, how would I go about regulating the voltage to the pump. There's a molex contecter and a 3 pin fan conection on the pump wiring. I have the 3 pin fan connector plugfged directly to the mobo. Not sure if it can be regulated from off of the motherboard. What are your suggestion on feeding the pump more volts? I just believe that the flowrate of the pump is a little slow and would like to speed it up. My system is running a bit hot for a water cooled system. Right now at idle it's at 43c/109f. Any help with this would be greatly appreciated. Thanks.
