VMWare vSphere Client vs Web Client passthrough problem
David-Duc
Hello guys, I recently run into the following problem with the vSphere Web Client while trying to passthrough my PCI-E ethernet card (Dell U3867 / Intel 82572EI). When ever I tried to power on the VM after adding the passthrough PCI-E device, it would always show this error even after I tried remove / re-add the passthrough device to the VM:
https://kb.vmware.com/selfservice/m...nguage=en_US&cmd=displayKC&externalId=2001216
"The systemId does not match the current system or the deviceId and vendorId do not match the device currently at <bus:device.function>"
However, when I add the passthrough device to the VM using the vSphere Client (windows installation), everything goes fine without a single hiccup. Is it me or the vsphere web client just crap? If it is crap then how could VMware limit some functions to the web client only?
/Host:
ESXi 6.0.0
FX 8320E + 970A UD3P mobo + 32GB DDR3 + Dell U3867 NIC.
Are you using the vCSA or the full vCenter?
What hardware version is the VM?
I agree with you, it is very strange that the web client doesn't work but the thick client does - sounds like a configuration issue as vCenter is way more sensitive about configuration (found that out the hard way last night).
Have you tried removing and re-adding the host to vCenter?
