Alright, so I got these two Delta AFB1212GHE 120x38mm fans that are fantastic, the only problem is that they can be a bit loud for invited guests and what not. So I was thinking of trying to make a switch that would switch between 12v and say 7v. I did some calculations for getting to the 7v via resistors and I came up with this:
I = 29.4w/12v = 2.45 Amp
R = 5v/2.45a = 2 Ohm
P = 2.45*5v = 12.25 Watt
2Ω/12.25W resistor x 2 (1 per fan, each fan on separate switch)
http://www.sidewindercomputers.com/deaf12recgrh.html
I think those numbers are correct but that seems like a huge resistor and the heat output of something like that worries me a bit.
I was wondering if you guys had any suggestions for other ways of doing this or if this way is safe?
Thanks
Thanks
