win7 should work the same way as vistaIs there even a version of vLite (or whatever they're going to rename it as) for 7 yet?
How many of you plan on optimizing W7 further?
I have to ask this very question. It amazes me that some people didn't figure out these tools were useless with Vista, and here we are three years later, with even less of a reason to use them. By the way, the install is pretty much unattended already. There's no reason to eneter a key during the install anyway, so why bother. Just install it, and follow the best tweaking advice there is....leave it alone.WHY GOD!!!!, WHY!!!!!![]()
No way! I gotta run a defragmenter 3 times after a clean install, disable my page file, and repeat every 2 weeks or for any device installation, driver update, or major software update, whichever comes first. It's the only way to run your system and optimize the megahertz!!!Leave it alone.
Leave it alone.
Agreed. Some folks just don't let old habits die.Leave it alone.
Yanno, when XP came out, given the state of technology, and the "power" of machines, CPUs, RAM, hard drives, video cards, it was actually advantageous to do some optimization, to remove some stuff that wasn't of any use that drained some level of resources, to tweak some services that could potentially have come into play to tap a little bit more resources, etc.
But this is nearly 10 years later. We have processors for $50 nowadays that have dual cores and are more powerful than anything that existed 10 years ago, even if you had a machine with 32 freakin' CPUs in it.
The whole concept of tweaking is now passe, really. Today's machines are so god damned inherently fast that this stuff is just ridiculous to even see it still being put to use, and I've been using nLite and vLite since before either of them were actual publicly available apps, having created hundreds of very "light" installations of XP for specific purposes.
But nowadays, if you did all that, if you tweaked everything possible, if you gutted out Windows 7 into something that easily fit on a 700MB CD will room to spare for a whole lot more, I seriously doubt you'd do much of anything except:
a) gain a few percentage points overall, and I mean a few, if that many, like less than 3-5%, and...
b) end up fucking up Windows 7 in the process because you're taking something that is a high performance (laugh if you want, I couldn't care less) computer OS that self-tunes to make itself even faster, automagically defrags when required, monitors itself, tells you when things go wrong (Reliability monitor), and many other things that no other computer OS has ever done before, on any architecture, or any platform... Linux, UNIX, FreeBSD, OSX, etc... all be damned. They all pale in comparison to what Windows 7 actually does and brings to the table...
Well, be my guest. You can proudly go around informing people of your "success" at gutting out Windows 7 while the rest of us that understand how things actually work just mumble stuff under our breath and laugh at you not only to your back but to your "public" face.
Sorry, just had to let that out...
Leave it alone should be stamped on every Windows 7 disc and box, and I almost wish it was self-aware enough to pull a H.A.L. 9000 move when you try to muck it up and alert you with:
"I'm sorry, but I can't let you do that..." or words to that effect.![]()
fanboi ftw
or at least creating an unattended install?
WAIK.that is the mistake everybody makes when they hear the word vlite. they think people use it just to decrease memory use. granted that is one reason some use it. but there are other purposes for it including slipstreaming service packs and updates and integrating drivers. plus unattended installs too. as long as you read the posts in the forums and know what you are doing it is a useful tool. to many try it to just see what it is and screw up and blame the program when it is their fault for not researching and asking questions before they screw up.
I just looked at the vLite Vista page and it looks like you need to download the MS tools that take care of all this in the first place. Is the Vista version just a front end to the MS tools? I don't really care to look because the MS tools get the job done already.I guess that's why the OP specifically asked:
We all know exactly what the OP is asking, what it implies, what the intentions are, etc - however his second question:
almost redeems the situation because vLite (and nLite) do offer those other benefits that hclarkjr just touched upon.
The simplest answer is: you're just wasting your time if you intend to gut Windows 7 "down" and you will end up doing more harm than good, more often than not by the procedure. If your intention is to create unattended installations, add drivers that don't exist in the installation media, etc those are all excellent reasons to use vLite as it will make doing such things much less problematic.
fanboi ftw
XP IS DEAD. It's a dinosaur of an OS that needs to be retired. And take your XP ideologies with it.
Except for slipstreaming. I wish MS would make slipstreaming W7 as it was in XP.
^Drivers, hotfixes, official patches, service packs. Sure Slipstreaming isn't going to be a big deal now, but after going through four service packs (i.e. Win2K) and with new hardware coming out in the years to come, it wil be.
Causes more harm than good IMHO.
Leave it alone.
FWIW, WAIK will allow you to customize your installation. The components and settings are very configurable this time around.
He speaks the truth. Trying to remove stuff and customize Vista/Win 7 always led to disastrous results.
Either learn how to Windows Automated Install Kit (It's on Technet/MSDN) with answer files and sysprep.
I learned how to properly rollout a network containing completely different machines with Vista/Win7 and install hotfixes/drivers.
Also, learn linux if you want a "light" OS. Try Slackware/Slax. Heck, you can install it on a USB 1GB key and still have ~500+MB left.
