StefanPeeters
- Oct 7, 2013
Hi,
I am trying to implement vlans but not seem to get it working. I hope that someone can help me with this step by step. I will now write down how I think it will work. But it doesn't.
I have the private ip address 192.168.0.1/24 for the router. I have a procurve 1910 24 ports (je006a).
First I go to the menu on the left side of the 1910 and select 'Network - IPV4 Routing and Create' Here I enter as Destination IP Adress 0.0.0.0, Mask 0.0.0.0 and Next hop 192.168.0.1 and as Preference I take 10. Now I click on Aply and I see I have the route when selecting Summary.
Now I make some vlans by selecting Vlan under the 'Network' tab. I select 'Create' and fill in 2-3 for making three vlans (default included). I give them the name public and private.
After doing that I assign the vlans to some ports. For example ports 9-16 in vlan 2 (public) and ports 17-24 in vlan 3 (privat). After I select the ports and type 9-16 in the field (Vlan IDs). Because I want to connect some pc's and servers I chose for Untagged membership. When I select 'Apply' I see a popup that says that the ports are changed to Hybrid. Ok I gues.
What I do then is selecting 'Vlan Interface' also under Network tab. I click on create and type these information in the open fields:
First
Vlan ID: 2 (for public)
Select Manual
Ipv4 Address: 192.168.2.1
Mask Length: 255.255.255.0
Apply
Second
Vlan ID: 3 (privat)
Select Manual
Ipv4 Address: 192.168.3.1
Apply
When I select Summary I can see they are there. I also don't forget to save all the configurations I made.
Now when I ping to 192.168.2.1 and 192.168.3.1 I get 'Request time out'.
I tryed this for so long and I realy would be very thankfull if someone can help me in getting this to work.
First
Select Manual
Apply
Second
Vlan ID: 3 (privat)
Select Manual
Apply
