mrmylanman
- Jul 13, 2008
Hey guys,
I just got a new Vista machine at work, and I noticed network transfers are absurdly slow. We're talking about 5-8KB/s When transferring about 1.5GB that is over 24 hours. I was wondering if there was a solution to this problem, since it is very cumbersome.
I did notice that with the Remote Differential Compression turned off, and "network autotuning" disabled, it will speed up to 60-80KB/s.... after transferring for a half hour.
It is a 100MB/s connection.
I heard something about it could be an issue with Explorer taking up a lot of RAM during network transfers, and this computer only has 894MB of RAM, however right now as I am transfrering data, it is using 636MB, although I did notice that 740MB is being used in the page file, so maybe some important stuff is getting thrown in there.
Do you guys know what could be causing this? If it's RAM... hell this is so frustrating that I may just go ahead and throw some in there out of my own pocket because it's pretty unbearable.
