....shows a lot of little red x's...like you see when you go to a web site that is missing a image...when I access it, some pages in help worse than others. Anybody else getting this?
have you changed anything in your security options for IE? firewall blocking it? hmm..
EDIT: maybe you're getting an error with offline help at the bottom. that might be it. click it and then click online help...then if you wanna be sure, click it and then go to settings and click the first check box. then click ok.
Online help is on...and if I turn it off, I get a LOT more of those little red boxes. Clear your IE cache and try going to help/table of contents..maybe the problem is on Microsoft's end?
I was tinkering a bit...did a clean install of Vista, step-by-step....upgrading Nero 7 Ultra version 7.x to 7.7x is what hosed the associations. Downloading the upgrade as a clean install (available from Nero's website, you just need your serial number) doesn't kill the file associations. Go figure...
