Hey guys
Would adjusting the “Audio Share Mode” under the advanced tab in speaker properties cause the system to hand/crash?
For those who don’t know, click on Control panel > Sound > Speakers properties >Advanced
Thing is, I’ve been experiencing some problems where at times; the PC will just freeze/hang when using multimedia applications. I’ve tried using both Vista x64 and Vista x86 with SP1 but ended up with the same results. I’ve updated all the drivers but I did chance the audio share mode value to maximum (24bit, 192,000 Hz Studio Quality from 16bit, 48,000 Hz DVD-Quality.
If you guys know of fix, please let me know as soon as possible.
Here’s my full system spec:
PS: SP1 didn't show up automatically in Windows update, and I did a manual install. I know creative have problems with Audigy cards, but what about X-Fi XtremeMusic cards? Are they on the same boat too?
- Motherboard: (Media Series) DP35DP with the latest drivers from Intel
- GPU: ATI HD3650 with CCC 8.3 (Unfortunately, it come with HDMI audio driver, which Vista installs during OS installation)
- Audio: X-Fi with the latest March 08 drivers. I’ve also installed the latest console launcher.
