First of all, see this image for reference:
![](http://img371.imageshack.us/img371/3727/tempim4.th.gif)
Info: 4gb of memory, Vista 64 bit. I haven't changed any settings as far as page file/memory configuration since I installed it.
1) Under the Task Manager, Physical Memory reports 4093 total MB, 2981 MB cached, and 22 MB free.
- Shouldn't it say 1112 MB free? (4093mb - 2981mb = 1112mb)
- Furthermore, the bar graph above that in the Task Manager shows 1.75GB used which is completely different from the 2981 MB cached number below. I'm not understanding where it's getting these numbers from.
2) Under System in the Task manager, the last line says Page File: 1665M / 4022M.
- First of all, Windows didn't set up a page file (see Virtual Memory dialog box I have open). Why does it say I have a page file of 4022mb?
- Okay, so I'll assume it's just putting numbers about my RAM in the area where it says Page File, since I don't have one. But if that's the case, the 1665mb number is completely different from the other two numbers discussed above in point (1).
- Or is it really a page file? Everest says I have 4093mb RAM, 4022mb "Swap Space", and those combine for 8116mb "Total Virtual Memory". If it's really a page file then why is it there when there's no page file set under the Virtual Memory box?
