My wife does work on the side that requires rendering. As a kind of geek hobby, I have three ESXi servers running at home (Sandy Bridge Era and later). These machines largely stay relatively idle. She wants to speed up rendering. I was thinking that instead of upgrading her PC, I could install a VM on each host for rendering, and modify the resource allocation so the render VM is something like 1 share, and regular VMs 50 shares each for CPU resources. Idea being that the render VM would only really use time when other workloads were idle. Everything is hardwired and attached to 48 port gig switch with 2 gig ports on each ESXi host hooked to the network as LAG.
Since I'm not an expert on virtualization, I wanted to check with some of you more seasoned folks and ask if there is a reason I'd not want to do this. The home VMs largely run low power tasks (DNS servers, privoxy, VPN server, etc.).
