Vinyl Dye
motithejrt
My case theme is silver and this flourescent / royal blue. I need to get some dye for my drive faces. I went to 2 different auto stores and all they have is cream, lavender, gray, off white, and some other god foresaken colors.
Anyone know where I can find some this color (thereabouts anyway):
You could use the Krylon Fusion spray paint. It's meant for plastics. I bought mine at WalMart. Can also find at Fleet Farm, etc. It may not be quite as good as vinyl dye, but it'll do what you need better than normal spray paint.
I painted a monitor black, it turned out really well. I also tried a floppy drive, but that didn't go so well. You have to be reallly careful not to smudge it or anything before it cures.
Oddly enough, I used that krylon stuff, its pretty good. But right now, I am trying to paint some rubber molding the same color. The krylon does adhere very well.
