Viewsonic VX2235wm?
I ordered the viewsonic VX2235wm today at an IT fair..:D i'll have to wait 20 days before i can collect it. They said it's essentially a bigger 2025wm panel. Has anybody got it yet? :(
Here are the specs:
LCD Panel Type 22" Wide Color TFT Active Matrix LCD
Display Area 18.7" horizontal x 11.7" vertical; 22" diagonal
Optimum Resolution 1680x1050
Contrast Ratio 700:1 (typ)
Viewing Angle 170? horizontal, 160? vertical @ contrast ratio > 10:1
Response Time 5ms (typ)
Brightness 280 cd/m2 (typ)
Light Source Long life, 40,000 hrs. (typ)
Panel Surface Anti-glare
VIDEO INPUT Analog/Digital RGB analog (75 ohms, 0.7 Vp-p)/DVI-D (TMDS, 100 ohms)
Frequency Fh: 30~82kHz, Fv: 50~85Hz
Sync H/V separated (TTL), composite, sync-on-green
AUDIO Speakers 2x2.5-watt
COMPATIBILITY PC VGA up to 1680x1050 non-interlaced
Mac®* Power Mac™ G3/G4/G5 up to 1680x1050
AUDIO Speakers Two 00W speakers
CONNECTOR Analog/Digital 15-pin mini D-sub/DVI-D
Power 3-pin AC plug (CEE22)
POWER Voltage AC 100-240V, 50-60Hz (auto switch)
Consumption 48W (typ)
CONTROLS Basic Power, 1, down, up, 2
OnView? Auto image adjust, brightness, contrast, input select (analog, digital),
ViewMatch® color adjust (sRGB, 9300K, 6500K-default, 5400K, user color - RGB),
information (resolution, H. frequency, V. frequency, pixel clock, model number, serial number), manual image adjust (H. size, H. position, V. position, fine tune, sharpness), setup menu, language, resolution notice, OSD position, OSD timeout, OSD background, memory recall
REGULATIONS UL, cUL, FCC-B, CB, CE, ENERGY STAR® NOM, NEMKO/GS (covers TUV/GS), NEMKO ERGO (covers TUV/ERGO, ISO13406-2 & MPR II), MPR II, GOST-R + 20 original copies hygienic, SASO, PCBC, VCCI, BSMI, CCC, PSB, C-TICK, Argentina-S, Green Mark, RoHS
DIMENSIONS
(WxHxD) Physcial (mm) 524mm x 482mm x 244mm (with stand)
(W x H x D) 524mm x 388mm x 58mm (without stand)
Physical (in.) 20.6" x 19" x 9.6" (with stand)
20.6" x 15.3" x 2.3" (without stand)
OPERATING CONDITIONS Temperature 41-95?F (5-35?C)
Humidity 20-80% (non-condensing)
WEIGHT Net 13.2 lb. (6.0 kg) (with stand)
Gross 16.5 lb. (7.5 kg) (with stand)
