EuphoricRage470
- Apr 15, 2011
1455 rated boost eh? Expecting 1500+ effective boost, wouldn't be surprised to see this clock to 1800mhz fairly easily with some tweaking.
So much for glofo being the reason Polaris doesn't clock as high
The ones with the 6 pin I wonder if they will OC like the bigger Pascals? You talking around a 40% OC here at 2000mhz over default boost clock! If they go faster even more. At default clocks they appear to be wasting the 460. Does not look too good for AMD, lower end Pascals will consume the mobile market like Maxwell before.
As cheap as the 1050 Ti is I might as well just get one to replace my 570. It should be a lot faster and it gets me over the VRAM bottleneck on the 570.
Well the sad part, the gap for Nvidia Pascal generation over AMD Polaris is larger now than the previous generation perf/w at the low end/mobile market. Polaris 10 is OK for the price but nothing really spectacular, Polaris 11 I am beginning to believe is a flop.Well thats the thing everyone was so focused on AMD's perf/watt they all pretty much forgot what nV's cards were already capable of in that category lol.
Well if they don't fix their perf/watt with Vega all bets are on Navi, and if it doesn't happen there, man I don't see AMD ever coming back to the top end or even mid level anymore. The amount of money it costs to make these chips and time to rebound if you make a mistake is getting to the point that even one mistake in one generation can be the end.
I can't wait to see pages-long dissertations from AMD fanboys about how the RX470 destroys the 1050 Ti in perf/price while handwaving away that not-so-important thing called 75W TDP and the entire 1060 line.
Well that is true, but AMD needs to catch up first to what is there already.
well if Volta is going to be on 16nm or 14nm, I think its perf/watt is not going to be as great a leap as we saw with Maxwell to Pascal. This is hypothetical here, but at its max its going to be like Keplar to Maxwell, which is still damn good. Either way if Navi doesn't catch up on Perf/watt AMD has to pull out of the high end graphics business. Unless AMD's CPU division picks up enough to funnel money in their graphics..... Which I am skeptical by 2018 they will have enough money to do something like that
That Volta-based Tegra chip that nvidia unveiled a couple of weeks ago was certainly promising good perf/watt gains. Of course they were bragging mostly from the perspective of 8-bit int operations, so maybe they are doing something special there to get the performance that won't carry over to GeForce.
Volta is 16nm. Also, the perf/watt move from Kepler -> Maxwell was actually larger than the perf/watt move seen with Maxwell -> Pascal. Architecture matters much more than process node, as the last couple of generations have clearly shown.
As for AMD's CPU division, if AMD's GPU division -- which has put out reasonably competitive products over the last couple of years -- is getting left in the dust by NVIDIA, then what chance do they have against Intel?
AIBs ready
So, AMD claims that they want to focus in low/middle segment of market and wait with Vega, to consolidate their market share. WIth 1050/Ti, that strategy just is going down the drain. NV wins in premium and low-end segment, while only in 480X area, AMD can fight with 1060. If it goes, like it goes, NV won't have a reason to release 1080 Ti anytime near.
Geez, Nvidia isn't showing any mercy to AMD with Pascal, I don't think I have seen a whole generation of AMD/ATI GPUs slaughtered this badly before. The only thing the RX460 won is the on release date and that was only because NV was prioritizing the more profitable higher-end segments first.
I would actually recommend to all reviewers and hardware sites to ask Roy Taylor about the "months ahead" and VR TAM stuff. I think it is fair to hold AMD responsible for the promises they obviously failed to deliver.
