videocard dying?
Circuitbreaker8
Something is really wierd with my vid card recently....anyways I have a Sapphire 9800 n-p flashed to pro using the gigacube bios. Everything has been working fine since I did it about 6-7 months ago. Then games started flocking up this month...The screen would go to that no input signal check refresh rate screen, but i can still here the game in the background! I restarted and it was done. Then, when i play UT2k4 or frag ops, it plays fine for a while, the i here this nasty screetching sound from my speakers and the screen goes all blue. Sometimes it has white text and stuff. BTW i have a modded vga silencer with 2 80mm fans and im using the 4.2's. The heatsink isnt really that hot either... :(
