Hello All,
I recently purchased an accelero 8800 xtreme for my 8800 ultra and the added height blocked my sata ports, which are the kind that come straight out of the motherboard. The previous VGA cooler had plenty of clearance and didn't hinder the sata port connectors in any way. Here's the new cooler.
So i had to bend the sata cables dangerously tight to get the video card on, but it's very ugly as i had to do a lot of zip tying in different directions to off set the pressure on the SATA ports.
Solution: I found these--
I just wanted to share my little experiment with an oversized VGA cooler.
Since they are both right angle connectors, and one is lower than the other, they should nest perfectly with out any pressure from the video card. I just received them in the mail from cooldrives.com. The total came out to 16 bucks total for 4 (2 right angle and 2 ultra low profile right angle)
Here they are:
I'll post an update once it's all in and installed.
Also... Does anybody have any better ideas to my solution? I'm curious if i pulled a bone head move and overlooked an easier solution.
Here they are:
