what are some normal temps for a 9800gx2? i feel that mine is overheating and causing my computer to freeze/bsod. my temps are around 70c and the fan speed is only at like 45%. do i need to raise the fan speed and if i do, how?
Yup. My GX2 is usually in the low to mid 70's at load with the fan speed at around 35%.
Actually, I would try the new EVGA Precision tool to adjust the fan settings. It is a very easy tool to use and will adjust both fans concurrently. Just type in EVGA Precision into a search engine or go to the EVGA website. It doesn't matter what brand of GX2 you have. It doesn't have to be EVGA. Mine's a BFG.
After I crank up the fan speed to around 60-65% which is barely audible in my rig, the temps stay in the mid to high 60's at load.
yep i agree the EVGA precision tool is amazing and apparently works on all cards although i have an evga so i'm not too sure. Mine was running about 70c idle and now i have the fan on constant 80% and it is running about 55c idle
