Like the title said, I've been having various issues which I am pretty sure are graphics related that I cant seem to iron out.
Mainly, despite gaming with vsync enabled, disabled, and all combinations in between, (both via the catalyst control center, and/or the application settings) I still get major screen tearing. Even when out of an application, my 3rd monitor (the one connected via active displayport/dvi adapter) has a edge-to edge "scan line" slowly moving up creating a tear when windows are moved across it (or a video is playing).
Generally, the v-sync setting via the catalyst control center seems to do nothing, whereas the application v-sync setting helps somewhat, but introduces checkering.
When I do have v-sync and any amount of anti-aliasing enabled (even 1x for Bad company 2), I get "checkering" all over the screen; this is very noticeable during cut scenes. the level of checkering varies form very annoying to "cant see what the hell is going on".
Finally, and I am not 100% sure if this is entirely related to the graphics cards, but In pretty much any game I play I eventually get a crash to desktop. Time to CTD varies, but is about 10-15 minutes in. So far, this occurs during Just cause 2, Portal 2 (extremely consistently), and BF bad company 2.
I have pulled back all of my overclocks back to hardware defaults, but the problems still persists. My cards have never gotten above 95 C and usually hover around 89 C when at full load (I could run cooler, but me no gusta loud fans).
system specs:
Mobo:GIGABYTE GA-Z68X-UD4-B3
CPU:Intel i5 3.3GHz sandy bridge
Video: two MSI R6970's in crossfire
Ram: G.SKILL Ripjaws Series 8GB
6116x1200 eyefinity setup (3 monitors with bezel compensation)
latest drivers installed.
Edit: If I reduce the game resolution to 1920x 1200, the problems seem to go away (i cant confirm the CTD's yet). Any ideas?
system specs:
