that is a dvi to vga connector, most dvi output carries both digital and analog signals and can use either...... vga connector only carries the analog signal..so you would have toRiddlinkidstoner said:Get a VGA-DVI adaptor. They usually come with video cards...you could probably find them on ebay for really cheap.
Get a vga switch (non physical manual switch) should cost around 10 to 20 U$Dwxkid23 said:I have done some looking and can't seem to find a VGA to DVI cable... just some VGA to DVI boxes that cost over $200. My computer has a VGA out video card and my LCD has a DVI input (VGA is being used by 360) .... can anyone help?
Actually sethk, that's what I was implying too, a dvi to vga cable...I just bought one for $7 shipped on eBay, there is loss when you use the adaptersethk said:While the adapter will save you a few bucks, there is some loss of quality going this route. If you have a really good CRT or something, try one of these instead:
http://www.datapro.net/products/1145.html
I think this is the best suggestion. Anything that could convert from VGA to DVI would probably cost just as much as a 7600GTS, like this:movax said:IMO, if your videocard is lacking a DVI port, it's probably not even a great gaming card (most everything past & including Radeon 9xxx's and Nvidia FXs came with DVI ports), grab a cheap GF7300 or X1600 off newegg or here on the forums. I think you'll be a lot happier that way.
