PaulMuaddib
- Mar 25, 2004
Ok so I got my Notirake 2x20 VFD modules in.
Datasheet: http://noritake2.download.reliablenetworks.net/CU20025ECPB-W1J.pdf
Wired it up as per this website: http://www.icehw.net/article.asp?id=99
When I load LCD Smartie or LCD Center... it will display info. But not correct.
I made sure the settings were correct... but it seems to only want to put the info just about wherever it wants on the display. Like it is out of sync.
What I mean is it will show system stats... but not anywhere near where it says it should be displaying it.
I am kinda concerned because I found a VFD wiring diagram that is different for this display here at http://www.vfdworld.com/index.php?page=usingyourvfd
Notice at the bottom of that page... the #5 pin (r/w) is connected to Parallel pin #14. But according to ICEhw.com they just grounded #5 pin to molex black.
Could this be the problem?
Any info would be great... Thanks.
